SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 14, 2022 * 6 posts * 36 views
joemomma said: Jinxed myself the other day saying I drove it to work with no issues lol. This morning on the way in, got stuck in traffic. Noticed after sitting for a while the idle was a little ... Read more >>
June 15, 2022 * 14 posts * 216 views
Stangswagalicious said: So, i have an update. I had an epiphany today. When i replaced the timing components, i installed the stationary timing indicator a little crooked and it was rubbing on the balancer. ... Read more >>
June 14, 2022 * 6 posts * 99 views
RAU03MACH said: i would inspect every pin on that plug for spark arc any thing that dose not look right make sure pins are not pushing in while pushing on them for a secure fit Read more >>
June 14, 2022 * 3 posts * 23 views
ttocs said: if you can't get under the dash then you are not going to like to get into the trunk opening to disconnect them. They both hang from the bottom of the rear deck on the end of the ... Read more >>
June 15, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts IS350 brakes for gt? June 14, 2022 * 35 posts * 454 views Suspension and Brakes Squeal / Whine after engine turned off June 13, ... Read more >>
June 15, 2022 * 24 posts * 357 views
cobrajeff96 said: Yea, so not a loss. The batt light resistor might just be highly visible on the back side of the gauge cluster though. Could be an easy fix if that's it. And taking apart an alternator ... Read more >>
June 14, 2022 * 11 posts * 183 views
That Mustang Guy said: One thing I didn't mention and just outright forgot was the use of spherical bearings being used in the ears of the 8.8 or 7.5. Considering they are like 100 bucks or so. I do ... Read more >>
June 15, 2022 * 20 posts * 209 views
lwarrior1016 said: Well, I didn't perform the repair. Conveniently, I had to go home shortly after that. But yes it does suck......I remember. Read more >>
June 15, 2022 * 85 posts * 1,256 views
badass98svt said: Yes, many years ago. I've been running the same rear springs (H&R SS) since 2008 or so. Before that I had another set, and there's been a shorter snubber on since then. I've been ... Read more >>
Continue reading...
