Highlighted posts from Tuesday, Jun. 14, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
June 14, 2022 * 35 posts * 454 views
J_lope82 said: Brembo makes oem brakes in Monterrey Mexico. They make all the GM, ford factory brakes in that plant. I never thought brembo would make their brakes in Mexico but it didn't surprise ... Read more >>
June 13, 2022 * 3 posts * 23 views
94SVTCobra said: My low mileage, completely stock 1994 Mustang Cobra (#500 of 5009) squeals / whines for a few seconds after I turn the engine off. The squeal / whine comes from under the hood ... Read more >>
June 13, 2022 * 3 posts * 29 views
dwcopple said: How much would a head gasket repair run on average? Is it worth it or should I look to swap engines? Car has white exhaust, boiling degas bottle that spits coolant, and exhaust ... Read more >>
June 14, 2022 * 4 posts * 58 views
J_lope82 said: C106= Connector 106. It's a main harness connector. Make sure that bolt in the middle is not loose. Put a wrench on it. Just go snug tight. Read more >>
June 14, 2022 * 2 posts * 14 views
rjankow661 said: Need a little help, I've got an Amp draw I'm tryna track dow, and I wanna check the Amp, I've read elsewhere they can be an issue (Mach 460 ) Seeing as how I'm a 240 lb, 6'1, 64 ... Read more >>
June 14, 2022 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Spark knocking galore... June 12, 2022 * 11 posts * 105 views 94-95 5.0 - Specific Parasitic drain? How to find? AKA Mach460 removal ... Read more >>
June 13, 2022 * 18 posts * 177 views
JDMac34 said: Well, that turned into way more of a project than I was hoping for. I was adding stainless brake hoses, Powerstop rotors, Powerstop rotors, Hawk HP+ pads, and flushing the system ... Read more >>
Continue reading...
