Highlighted posts from Wednesday, May. 25, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
May 24, 2022 * 11 posts * 52 views
badass98svt said: Good to hear. No problem man. Thanks for returning back to the thread to tell us what the issue was. Read more >>
May 24, 2022 * 13 posts * 187 views
chrisp427 said: Not sure what spoiler it is but how much you want for it? Read more >>
May 24, 2022 * 13 posts * 334 views
Makoto said: 1. @J_lope82 its a MM strut tower brace for a 99 cobra modified so it can clear the massive JLT intake 2. @badass98svt it has camber plates built into the coilover hats. castor ... Read more >>
May 24, 2022 * 5 posts * 41 views
Helomech74 said: Single bolt or 3 bolt tensioner? I use a Thump tensioner, but have also used the steel arm HD replacement stocker before with no issues. Read more >>
May 24, 2022 * 2 posts * 37 views
white95 said: Billet oil pump gears! Suggesting this because I forgot all about it when we did the cam swap in my wife's car! o_O Read more >>
May 24, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Stereo speakers fading in and out May 23, 2022 * 21 posts * 91 views Electrical & Stereo Wheel spacers May 23, 2022 * 24 posts * ... Read more >>
May 24, 2022 * 10 posts * 191 views
SouthernGorilla said: On my way to pick up my GT after getting my wife at the train station. Turns out the problem was a frozen caliper. Shop had to replace the bracket and guide pins, but otherwise ... Read more >>
May 24, 2022 * 7 posts * 161 views
Weekend Warrior said: Kinda looks like it drove through something and had an allergic reaction from it. Read more >>
May 24, 2022 * 15 posts * 152 views
LEGALLYFAST said: For being just around town, you just have to plan it out. Really with any build, it will help you later. I like to suggest superchargers because your car is like a normal car except ... Read more >>
May 24, 2022 * 25 posts * 462 views
badass98svt said: I didn't do a before and after Db test, I should have though. It is most definitely more quiet inside now, but not as quiet as I was hoping for. :D I even installed a new Mass ... Read more >>
Continue reading...
Suprasuavy
