How not to take care of your AODE
94gtstang50
Never change the atf, don't ever check its level, and forget about changing the filter. Make sure you dont do this every year and you'll have no clutches in no time. Neutral dropping it also helps it not last longer.
94gtstang50
Anyone know what ATF does to a T5 or any other manual trans?
wayne94mustang
nope.......rule of thumb is if it has an aluminum case use atf.....if its cast iron/steel use gear oil
97vertstang
hey 94gtstang50- u confused the shit out of me on the last one :dunno: so neutral dropping it bad or not??? i do it all the time to either rev on people or to cruise down a hill. ;D
94gtstang50
Do you rev it up and while its at like 2-4k rpms drop it into gear?
97vertstang
oh no i dont do that .i rev it up and when it comes down a drop it into drive.
94gtstang50
Thanks, I just need to get her looking good so I can start on the performance stuff. My plan is for her to be all stock on the outside, except for wheels, and maybe clear corners, and make her a performance beast.
HISSIN50
94GtStAnG5o said:
So which years have which?
Seems to me that gear oil was used up through like what, '83? With the advent of the WC T5, Mercon was spec'd.
riored96gt
SoCal 909
My '86 Turbo T-bird was the first car I had to spec ATF in the gearbox.
Suprasuavy
