How to repair window motor bushing - 94/95 cars only
A few weeks ago my driver side window wont go down without me pushing it,same thing to go up,but i was able to heard the motor running and a clicking noise so i decided to take the window motor out and surprise the bushing were worn out,so i went to the parts store and bought the bushings and got it fixed now it works like new up and down.now im goign to tell you how and what you need:
Tools needed:
*Bushing can be found at autozone,O'Reillys or Advance auto parts for about $6.99
Part No. is 74410 specs of bushings are :
Diameter:.595"
Height:.429"
*Phillips
*5/16 socket
*Flat scredriver
Step 1: ok first thing open the door (of course)
Step 2: now see the black part that you use to shut the door that needs to come off,on the top of it stick the flat screwdriver
and pop it loose,once that is done pull it straight up, on the back of it there is the power mirror switch unplug it, then
unscrew the two screws to free the lock/unlock harness
Step 3: Take off the two screws that are near the center of the door panel.
Step 4:Now pull the panel door up and then feed the door opening handle thru the door panel.now the door panel is off
Step 5:the window operator is east of the door,peel back the plastic as necessary to get to it,then unplug it,now fish it thru the
little hole
Step 6:Take the speaker off it has 4 screws
Step 7:now peel back the plastic as necessary to get to the 3 bolts holding the motor
Step 8:takes off the three bolts holding the motor,make sure you are ready to catch it or will fall inside the door (no biggie),get it
out thru the speaker hole.
Step 9:eek:pen the motor by uncrimping the two crimps and pop the cover off surprise !!!!!!all that stuff is not garlic is whats left of
your bushing,at the end of the shaft there is a clip,spread its ears and slide the clip right off (pics no.1)
Step 10: pull the gears out and clean the inside
Step 11 put your new bushings in
reassemble everything and you are done
I hope this helps everyone.
NOTE: Passenger is almost same thing
1FastGT
Re: Window Problem 94-95 Only
you can put in 1/4" nuts. it actually works better cause they dont wear out and break down like the plastic rollers. thats what i did. :xmas-smiley-022:
ive heard about that,but nobody was able to prove it with pics,i will try that whenever i have to change them again :D
94IVGT said:
great write up man
thanks, i hope this helps everyone :santa_afro:
1FastGT
i did it on my driverside window works perfect for me.
stang4u2nv
Great write up but i did it in a different way you do everything he said but instead of replacing the bushing with the plastic pieces just go ahead and buy 3 small nuts i can't remember the size right now maybe 5/16 or something and they fit perfect in the spot where the bushings go.. now your window will only break if the motor itself burns out but never again will you replace plastic bushing, because now they will be made of steel, oh and by the way this works for almost every ford vehicle like crown victorias, lincoln, expedition explorers anything that is ford....
Probably next week,i will try to use 96-98 window motors (They have no bushings) i havent done any research for fitment issues and also i will try the One Touch Window Passenger Side,if i get it done ill get the write ups for it too. :xmascheers:
Stangbangin
Good info..thanks,...i was wondering if the window stays up on its own when you get the motor off. Or,do you have to secure it somehow before the motor is removed...
it stays up.
slowfivoh
I just picked up a convertible and the drivers side quarter window is hanging up if you lower it all the way. Do you think the quarter window's bushings are bad. It only hangs up if you lower it all the way, if you leave it about an inch or so up then it doesn't have a problem.
can you hear a clicking noise?
slowfivoh
I can't hear anything from here, I'm deployed and I a friend's dad picked the car up for me, I'm just going by what the previous owner said through an email that he sent me. He said if you put the window all the way down you have to grab the molding with needle nose pliers and help it come up the first inch or so, then it does fine.
It sounds like the bushings are wornout.
Lane478
Ok I'm pissed. Why didn't I read this before I put Dynamat over my whole door panels. Hope mine don't go out. That crap is impossible to get off.
oppsy!! LOL
Asylum938
im not going to lie Im 100% happy I found this post before I went out and bought a new window motor!!!
gopanoz
"I just picked up a convertible and the drivers side quarter window is hanging up if you lower it all the way. Do you think the quarter window's bushings are bad. It only hangs up if you lower it all the way, if you leave it about an inch or so up then it doesn't have a problem."
I have the same problem for the last 5yrs. I just remember not to put all the way down. To get the window back up, take off speaker, reach in with small hammer and hit stuff but not the glass. This worked for me. Probably hit the motor or sumthin and it started working again. Have no clue why it sticks.
AJ Foyt tought me that a hammer usually resolves problems the best way possible. :hammer:
d232
I just did mine today. It took less than an hour to do it, and would defiantly be faster now that I've done it once. The bolts on the motor are 5/16", for those who would like to know.
topless95
I wish I would have joined this forum a month ago. I ordered a new gear from Mustangs Unlimited, and guess what- the wrong gear was in the package, so I ended up buying the whole motor.. I had no idea AZ sold the bushings in the help section. Well I guess you live and learn! Great write up though :thumb:
topless95
Yea my local Autozone has em for 7.99, what is hard to belive is that pep boys also has them but they want 12.99
Mysticcobra
