joemomma
- Joined
- Dec 9, 2020
- Messages
- 1,274
- Reaction score
- 775
No, but I do have a MSD coil and cap/rotor.
assuming the coil is in the stock location it should not be a problem. So far if I am not mistaken now you have replaced the deck, rca's, and amps? Other than removing/cleaning or adding grounds I do not really have any more ideas.
I have mine on a breaker right at the alt on the wire from the alt to the stock fuse block/dist block but I am also trying to protect an expensive high current alt. There are fusable links in the stock wire from the alt to the stock fuse/dist block as well. One of the first rules of mobile electronics is you always fuse the power wires...I still need to replace the power wire from the alternator to the distribution block. Does this require a fuse or anything?
It depends on what size wire you run.Gotcha. Seems like I remember reading about the fusible links at some point. What's a good amperage rating for that wire? I'm just running a stock alternator, and would likely replace with a similar one if it ever fails.
EDIT: Gorgeous engine, BTW!
nah man just have them tint the whole front. Years ago I had a buddy with an rx7 that did that and it did look cool. Cool enough to get pulled over 2x in 2 days a week after he did it and they normally never care around here.Dropping the car off for tint at lunch today, will do 20% all around. Do the cool kids still do a strip across the top of the windshield? We always did in the past, but I'm not sure if that is still a thing or not. There's no matrix/dots across the top, so that should be doable I think.
