July 2016 ROTM - Voting
Status
Not open for further replies.
Orange 94
Alberta Canada
Time to vote for July 2016 ROTM! :)
Frank.JD.Perez
exterior
oem cobra front bumper and fog lights
oem style cobra front lights
carbon fiber svo side skirts
carbon fiber s281 spoiler
ford racing FR500 rims (275 40 18 all around and 1 in spacers in rear)
led 3rd brake light moddified with a flash rate
slow rate sequential tail lights with flat black bezels
side rocker stripe in flat black
flat black hood scoops
flat black roof
lots of stickers!
interior
white face gauges (speedo & hvac)
replaced gauge lights with white leds
sony xplod stereo with bluetooth
oem mach 460 system
10th anniversary style mystichrome cobra steering wheel
performance parts
78mm bbk throttle body/plenum combo
airaid ram air cai
steeda timing adjuster at 12*
steeda cc plates (3 bolt)
ford racing lowering c springs with one iso on fronts and isos on the rears with a coil cut
magnaflow tru x off road x pipe
magnaflow 4x9 performance mufflers
offset twin 3.5 in tips with custom side exhaust piping
ford racing 410s with frpp speedo re-calibrator
13in front cobra style rotors w/bullitt twin piston calipers
maximum motorsports ss front brake hoses
16%2B-%2B1
B.mad
Suspension/chassis
Prothane rack and pinion bushings
Steeda X2 ball joints
MM XL subframe connectors
MM 2003-04 Cobra CC plates
MM 375lb/225lbs front/rear coilover
Bilstein/MM Sport struts/Shocks
FTR bash bar
MM PHB/TA
MM 6-point roll bar
Brakes
Hawk HP+ pads
Mosul 600 brake fluid
Wheels/tires
Bridgestone Potenza Re-11 275/30/19
Bridgestone Potenza Re-11 305/30/19
CCW Hybrid SP16S 19x9.5 19x11
Exhaust
BBK ceramic coated unequal headers w/ Stage 8 locking bolts
BBK O/R H pipe
Magnaflow Magnapack catback
Motor
BBK CAI
BBK 76mm MAF
BBK 70mm throttle body
MM solid motor mounts
Setrab oil cooler w/dual Spal electric fans
Custom boxing of the radiator
McLeod Super Street Pro clutch
Energy tranny mount
Stifflers tubular tranny cross member
Steeda adjustable clutch cable kit
Steeda Tri-Ax short shifter
Exterior
Custom autocross style spoiler w/ FTR support rods
Trufiber 3" crowl hood w/ TrackSpec Motorsports GT500 Heat Extractor vents
AeroCatch hood latches
MMD hood shocks
Cobra bumper w/foglights
Custom Airdam
SuperbrightLED front blinker/side markers
SuperbrightLED rear brake/blinkers/running lights
SuperbrightLED reverse lights
Depo Projectors with black housing
Clear front corner lights with black housing
Xenon 35w 5000k HID and 35w 6000k foglights
SuperbrightLED flasher
And a whole bunch of stickers
Interior
Braum Racing Elite Series seats
Braum Racing 6-point FIA approved harnesses
UPR crotch strap bracket
Nardi Torino Challenge steering wheel
NRG Short Hub/Quick Release
Modern Billet Mach 1 shift knob
Bulitt style pedal covers
Blue LED swap for gauge cluster
Carbon Fiber wrapped gauge cluster bezel
Backseat delete
2004 Mustang Center Console and Radio Bezel swap
Jensen VX7020 Touchscreen w/backup camera
RedlineGoods shifter boot, e-brake boot, and arm rest in Nappa Leather with Violetly Blue stitching
LED Dome light swap
Montclair Plaza, Montclair, CA by brandon madrigal, on Flickr
SCCA El Toro, Irvine, CA by brandon madrigal, on Flickr
Mustanger
A rundown on my mods
I have added the full Eibach Prokit Plus Suspension Koni shocks, struts, springs swaybars, MM adjustable LCA's, MM full length subframes, Magnapack Catback, Staggered DD Black Bullitts with 275/315 Sumitomos, Steeda TriAx, Steeda clutch quadrant & MM firewall adjuster, Steeda CC platres, drilled & slotted Baer Decelarotors with Bullitt/Cobra 13" front brakes & 11.75” rear conversion, Russell SS brake lines, a K&N drop in filter. I found a new OEM Ford distributor & added 9mm Ford plug wires to match the red MSD cap. Almost forgot the FR500 steering wheel! A great mod!
I have 3:55 Ford Racing gears and want either a MM Panhard bar or a Steeda Watts link setup. I have a 95 Cobra intake waiting to get powder coated and a new 65mm Ford Racing throttle body but am waiting on the AFR 165 heads & an E cam to install all at once as a package when I go through the engine or get a short block.
As you see I like Roush products so I striped it to resemble the 360R series of Roush cars & added the banners & badges as well... I added the front Roush splitters & Roush wing from the full bodykit I won on Ebay...the last one in existence from Roush factory! The side exit exhaust is next & the rear bumper cover as soon as money allows. I also picked up a brand new set of Roush Magnaflow side exit mufflers to help the install, you can't find them anymore either.
My car is 22 years old now with 170k miles but still gets likes at shows etc…I just know I love it! Thanks.
neverenuff
Engine
'12 F150 5.0
'11-14 Mustang intake cams/ intake manifold
FRPP Coyote Control Pack
Power by the Hour coyote swap bracket kit
Fidanza Aluminum Flywheel
RAM HDX Clutch
Canton P/S Reservoir
K&N CAI
255 lph Walboro
SVE aluminum radiator
MMR Head cooling mod
Moroso Battery relocation kit
B&M Pro Ripper shifter
BBK swap longtubes
BBK catted x pipe
MAC 2.5 catback
Suspension/chassis
UPR K-Member + tubular control arms
UPR front coil-over kit
Tokico blue struts/shocks
FRPP "C" rear springs
Steeda rear upper/lower control arms
MM full length subframe connectors
MM 6 point roll bar
Cobra/Mach 13" front brakes
Power Stop Rear brake kit
Stifflers Transmission Cross member
Summit D/S loop
Body/wheels+tires
Cobra front bumper cover+ foglights
Cervini 3.5" cowl hood
Depo Projector headlights
Corbeau GTS II seats
FR500 17x8 with Bridgestone Potenza's front, 17x10.5 rear with Nitto NT555's
I6Y-Kwxtfk1ZW0U-OVMjgPNz7lcTrsrGgNDSLUOsfh02LTrrn2CuEspZgwOctBpbz9nGIbUxQqFhVkutDgGG9fntdnyfaF3rIbrZpTyN8ZZnwUn_y0qOo0B1lY7SqbftsfJsqpIYnXcj4Wh6RghfNT_Ku2i3QuCDs5fv1hGD-cnHHkKudud06dEc0XOrCN1FlJk-03_A_KtSXWkL8WY9EZQ8mp5E3ZMZHSQAxQf4FK9zyMQGfsahQTx-xptGu9d_25RO6lmvKVYJSvB3-13vGPDNzqkCDnuP5A8VdByLIhuJP4LK6ZCLo-FDvh5mzVTXSAm4i98LaV8bjQIvGfcvM42A2Q80oCwwU5qxTIK5-ebU9reKeF4xLdBMBHTJgE9UmAcz7nKOduy2MJ4JsXx497QxHhZdKiWvJ61yJ6pfA8hlS9z1bzHyDBPbz9mWgbYYInUTmAz58TS5BUQHZVmDorZ98kGKm2OTpEhKtZDCwP1MZWCLUss11A89juY-bpq5x2S-b35QLT4y1VSn7aAeNTsk53NgV0o-DDFIPBvE44Zj1-v8myXj-ZWy_Gy2HWlDbovIPbkFeCdcVT0WaDxXzmS-DT553WI=w1343-h893-no
VlJVhUk7NJ8gQnb2hGw07oyXRnGdTLRN3yFDEtArezOIRNKqyXzdybCZYLNA6T-4KJwLsl_dzjQSetMTZJJlBWG0SgvZGh9j5Lpe5U_TsmDtUMO82BNFSGZX9kDfn0_aWv96sCbqs2rO9gUCEcfFBXGVoF1ti2t1YjbVLGFq72SPv7HPuTOa3l4lK-qt2pF7xLbzANMeqfm9Vy8rrZXbSTf5jIBenwgFeXcXbzoqsi-fqkC96DYPFXEAPpJxYCWnSmqSHyGTPpXGhpusb2K9GpUn-mxMkTqh5Y2dTHsNebgFj9nOuzZTvLoynY_5YkclOftBkGwX4RyrGvZiJD9dEpkmq8KDx5wP_9D0LA1AZHNSNFtF-zl_c6pDPiGT_FgSbX07hL1KsYmda08rTCjbs89b9FhstLTxVVFSK6qfeLt72uM4X_GjgOtMAkAHd8gCkCfuhlK1q7fjEm3Qf5R4IchEe7PqiABt07NlzSqzATGRQzw-JFgc_VYa4zi3hTYN-yQ-Lg_SuNLoMpRUXlVJ4HOvqEowAzmR24eDK_sMxl1nSVBQW_ahAU35T_9yeV4J5esf457IjxeAS0YWrxknv00UeXqxNT4=w1343-h893-no
mcglsr2
Orlando
Wow tough to choose - all really great cars guys!! Good luck to everyone!
Mustanger
Southern Oregon
LOl...what a race! great cars all for sure. I consider it an honor to be included in the group. Thanks everyone.
B.mad
Preferred Vendor
SoCal
Everyone, close your eyes and click. Theres your choice x)
neverenuff
What Mustanger said, it's an honor to be nominated!
Sent from my SM-N900V using Tapatalk
Status
Suprasuavy
