k member???
945.0
Milton, Wisconsin, United States
so i just got my upr kmember got it bolted in untorqued right now and i put the steering rack back in and on the passenger side it hits the motor mount and does not sit flush like its supposed to my ? is has anyone ran into this problem and what did you do to correct it.
MustangChris
Aurora, CO
your steering rack hits the motor mount??? ? ? ?? ? ??? on the passenger side??? ? ???
we need pics brotha.
Musturd
It hits the plate , yea I know what ur talking about its ****ing gay I just ended up taking a bit off the rack and just the tiniest bit off the k member .
945.0
easy mr. mc on the nice rack for an avatar you shall get pics tomorrow. lol
i mean its no more than 1/4 inch at most. did you have issues with the tube a arms? what are the sleeves for do they go inside of the bolt holes and then the plastic pieces go on them too? i didnt get instructions for it. but yes the rack hitting the plate pissed me off
Musturd
It hits the plate on the k member .
. You can see what he means in the pic
The sleeves go inside the bushings . I don't know if I had instructions either only for the coilovers and caster camber plates
Marvin97
Glasgow, Ky
interesting. I just installed the UPR kmember/arms in mine (4.6) with no issues
Musturd
That's mainly for not running bumpsteer isn't it
Musturd
Yea dude mine does the same . You're not the only one so I fixed mine . Dropping my engine back in tomorrow .
945.0
my friend whos been helping all along stated maybe use washers to space it out without grinding anything and then have alignment shop compensate for it? i dont know if thats possible. about how much did you take off MUSTURD
Musturd
I just took off enough till it cleared it .
945.0
i just emailed upr about it. since i wont be able to go much farther this next 2 weeks {vacation} im going to see what they say although i most likely will grind for clearance.
Musturd
Today when I put my engine I ended up making some spacers on the drill press that pushed the rack forward enough to clear the motor mount plates now the tie rods sit way more in line as well . To do it how I did it you would need different rack bushings mine have flat level face on them .
Musturd
Yea you can do that I did it as well but after looking how the tie rods sit in line with the spindles I wasn't happy so I spaced it out
Suprasuavy
