Kenny Brown caster plus CC plates
J_lope82
South Texas
Has any one use these CC plates? I was wondering if they are a good choice? C0C528E5-F912-409B-9583-3FD5B7CDA797.png8B9AF5B4-DDAD-465C-A18F-46D10553634B.png
badass98svt
Normally I like KB (RIP Kenny). But in this case, just go with MM. That's not something to skimp on. There's another current thread with someone else having an issue with another set of 3 bolt plates.
J_lope82
J_lope82
South Texas
So the reason why I’m leaning towards these is the poly bushings. They supposedly create less road noise. And I hear good things about Kenny Brown products. But like everything else…. Back order.
J_lope82
J_lope82
South Texas
Correct, had them in my last 3 Mustangs. Poly bushings are definitely not a selling point for CC plates. You want something with a spherical bushing.
10-4 I’m not opposed to the MM. I just thought they would make more NVH than the KBs.
J_lope82
J_lope82
South Texas
Another thing that Kenny B advertises is that their CC plates give you more caster that any other CC plates. Not sure how true that is.
gcassidy
Maryland
J_lope, if you want to try the KB, your post reminded me I have a set in the garage. Got them put on by Brooks Performance long ago. But then replaced them a couple of years later with MM when I started doing time trials. You can have them for the shipping if you want. I sold the car a few years ago.
badass98svt
Just curious, what was your reason for swapping them when you started the time trials?
Not enough adjustment? Or?
J_lope82
J_lope82
South Texas
I’ll take them. Thank you Sir.
gcassidy
Maryland
Mostly. I ended up at 2.5~3 neg camber once removing some metal from the towers.
Also, sorry for the way out of date sig image. It's been a while since I've been on here.
badass98svt
Oh wow, so they were moving pretty good in the strut tower? No bueno.
Suprasuavy
