Lowering the stang questions...
ShredderGT
Las Vegas, NV
So I plan to lower the stang and do some suspension work. This is a DD only and I don't expect to put it on the track any time in the next 4 or 5 years. I had a couple questions so any help would be awesome!
1. Full length subframe connectors (should I do this before or after I lower the stang?)
2. Steeda sport or Ford B springs (are the B springs really smoother than the Steeda sports and what is the difference in the drop?)
3. How much of a difference is there with the ISOS in and out? And is there a difference between the ones that come in the kits and the stock ones?
4. Bump steer and ball joints, are they really needed for what I am looking to do?
I will be getting a MM strut tower brace and CC plates.
1. Probably doesn't matter too much but a good mod to have.
2. H&R Sport springs, Super Sports if you want your car to sit sexy.
3. Not sure but since you aren't dropping the car too much there's no reason you can't pick a spring that will give you a nice drop with the isos in *cough* H&R SS *cough*
4. Probably not but bumpsteer certainly can't hurt. See how the tie rods look after the drop and then decide.
Tony
ohio
i just took out the isos and didnt notice any drop.....kinda sucked but some say u can get bout 1/4"
peasant99
