Mach 1 Bits.
cntchds
I'm buying a set of Mach 1 springs hopefully on Sunday. I think that these are the same as the ones on the Bullitt since they have the same spring rates, but I'm not sure. I've also looked into buying a set of the Tokicos that are stock on the Mach 1 and the Bullitt, yet the ones for the Bullitt are almost a hundred bucks more. What gives? I also wanted to know if it would be alright to drive on my stock shocks/struts for a couple weeks until I have the money to pay for the shocks/struts, or should I just wait?
Thanks a lot guys, and sorry for the possibly stupid questions.
:thumbsup:
stang94X
yeah the stock ones would be fine but id wait anyways and do it all at once
C
cntchds
Mine have 210k miles on them, but they are working fine. I am wondering if I should buy the shocks/struts for the Mach 1 or if it's fine to just use the ones I have for good. If I can, then I can afford to get Mach 1 brakes (notice a pattern?) but if it is really ideal to get the shocks/struts then I can wait on the brakes until I save up another few hundred bucks.
C
cntchds
Just picked up the springs, and still want to find out if I have to get the shocks and struts or if running without them is fine rather than stupid. Let me know so that I don't want to blow out my shocks and struts, so I'd be willing to wait if that is a possibility.
stang94X
running the stock struts/shocks are fine, it just a plus if you upgrade to Tokicos
C
cntchds
The only reason I wanted to know was because of the jump in spring rate. The GT ones were 450/200 and the Mach 1 ones are 600/250 F/R. I thought that at least in the front that would be enough to possibly be bad for the shocks/struts. Thanks.
Rice_slayer
You should get the Bullitt suspension kit from Stangsuspension.com. You get the drop springs, shocks/struts, and front and rear sway bars for like $500, pretty good deal!
future9er24
well he already picked up the Mach springs for about $70, its cheaper to get the mach shocks/struts than it is to get the whole kit
still a good deal though, he just found a better one
it will be interesting to see if his car will now outhandle my bullitt. they'll have essentially the same suspension, but his car weighs less..
C
cntchds
I still think the Subframe Connectors would be night and day. They tie the car together so well...
Suprasuavy
