man these rear control arm bushings are killing me HELP?
tommybunz
i cant for the life of me get the rubber out of the metal housings so i can put the energy ones in. i called energy i orderded new bushings w/ metal cause mine were damaged im about to get some stock ones and put them back in. someone help.
NERD
Virginia
Drill several holes. If you're brave, use a torch and burn out most of the rubber.
95 svt cobra
Yes they are a complete whore to get in and out. The best way of doing it is with a press, or you can get in there with a punch and hammer it out. Slow but it works. Just make sure the housings and the bushings are nice and clean before you grease them up and install.
SRT Handz
you need to get MM LCAs instead of using the BS rain gutters
T
tommybunz
i've used a torch but it seems to only set the bushing on fire and not go all the way through. will try another way maybe a drill and dremel
95PGTTech
Yep, set it on fire and let it slowly burn. You can accelerate with PB blaster.
Suprasuavy
