I'll be shelling out the $500 or so for those lca's too. Soon enough.
Thank you, I guess I was wrong lol. I apologize.Here is the link, you can tell because both ends have bushings instead of one being pointed. http://www.americanmuscle.com/kyb-gas-quadshock-9404.html
Yeah that is kind of what you are supposed to do when exiting a corner if you want to get a decent lap time. Ask someone who does not just drive in straight lines. Why would eliminating a part (that ford put there to reduce wheel hop) eliminate wheel hop, that makes no sense. As sloppy as it is right now I do not even think taking it off would even effect it that negatively but why go through the trouble if your not going to replace it.Quad shocks only dampen in a front to rear motion, not in a sideways fashion. Unless you're gunning it out of a tight turn you should not be experiencing wheel hop, and if some how you are, eliminating the poorly functioning quad shock would resolve said issue.
Just giving my advice on suspensions. to me, the extra money is worthless for quadshocks, but, if it's that important you have them, then go for it =]
Solid axles actually put power down better than irs when exiting a corner. You would know that if you really were into racing or even throwing your car around a track. Nobody wants to admit it but look at the new Boss 302, it has faster corner exit speeds than even the m3. when you throw bumps into the equation thats where irs really has an advantage. Irs also usually has higher mid corner speeds. Another thing and I am not hating on V6s or any cars with lower power, but it probably did not have the power to spin the wheels on corner exits.you're being given advice from someone who road races....... I never had any quad shocks on my old mustang when I ran it on the road course, had worn out bushings in the rear, and not once did it wheel hop powering out of a corner. Did it wheel hop doing a burnout? you bet it did, so bad that it sent the head unit flying out of the dash when it was a street car. The experience you're having while cornering is the nature of a solid rear axle car. going around a corner it's not going to be as nicely planted as an IRS stock for stock, nor is it going to be smooth with the caveman styled T-Lok that ford uses. That being said, best of luck with whichever route you take.
