Mustang Rear Control Arm Install (SVE)
Jarrod@latemodel
MUSTANG REAR CONTROL ARM INSTALLATION (SVE)
Get rid of wheel hop with a SVE rear control arm kit. Available in black & red for 79-04 Mustangs, they feature urethane bushings for added performance. They not only help you get your power to the pavement but they also look good while doing it!
You guys make it seem so easy.
I had such a hard time lining up the axel bracket to the lower control arm and putting that damn bolt through :angry4:
Jarrod@latemodel
Jarrod@latemodel
Been there before. Sometimes it goes smooth, sometimes its a huge PITA!
Slipperman
Chicagoland
Due to the great salt belt, I needed to saw through one of the front bolts on the lower. A saws-all, four bi-metal blades and three hours later I was through. Then I needed to push what was left through using a ball joint press.
The press was needed to extract the rest of the bolts on the lowers as well. Took me the better part of a week!
Impossible_Fishy
