Hello all, I have a 2003 Mach 1. Recently I did all new tubular control arms and a BC Coilover kit. The car is probably ~4” lower than stock and rides great. I have noticed a very annoying clunking noise over certain bumps coming from the rear end. Upon further inspection, the rear sway bar appears to be hitting the differential cover. I took out the angle grinder and shaved some material off the differential cover to try and make enough of a clearance to prevent this contact, but it’s still happening. I believe this is the stock sway bar. Does anyone know of an aftermarket setup or alternative that would give me more clearance here? In the pics the axle is at full droop with the car on jacks, with the car on the ground the sway bar is pretty much touching the diff.
