Suspension Help...holy 4 X 4 batman!
LAFENATU
My car has one of the highest stock suspension mustangs I have ever seen.
It needs to be dropped REALLY bad.
I need to know what springs you guys recommend. The car is driven daily so I don't need an obnoxious ride. How well will a set of Eibach Pro-Kit springs do?? Are they not going to drop it enough?? 1 1/2" doesn't seem like it would do much but I could be completely wrong.
I was told to do Fox struts in the front by Maximum Motorsports as well because fox struts are a little shorter. Helps increase bump travel and decrease droop on lowered cars. Since I don't do any Auto X they recommended just to stick with a 3 bolt C/C plate.
Give me your input fellas. :headbang:
Paul
Ford C-springs and KYB non-adjustables have the best all-around bang-for-the-buck performance for a normal streetcar IMHO. I've had that setup on two street cruisers of mine and it's fantastic. Moderate lowering, reasonable handling, relatively inexpensive, and doesn't kill the ride quality.
L
LAFENATU
Are they going to drop my car enough to where it doesn't look like I am about to go off road??
Paul
This was my old '94 convertible. (R.I.P.) It had the setup I described, so you can decide for yourself.
L
LAFENATU
Looks good to me..
Your car sat as high as mine does??
Did you use plates?
Paul
Yes, I had Maximum Motorsports caster/camber plates. Actually, now that I think about it I don't know if that picture was taken with my tubular k-member and coil-overs or not. Either way, i set the front ride height roughly the same anyway.
Steven
SC
Damn paul, baller status yo.
Steeda sports have a decent drop. Its alot like pro-kit but maybe a little lower. With Tokico HP's and sports, I probably had the best all around package. However me being me, I love a slammed stang and found the sports to be just as 4x4, even though they aren't.
L
LAFENATU
The guy at Steeda said their springs only drop about 1" and the Pro-Kits are about 1 1/2"
I just hate the way my car stands.
wytstang
Here is my car with Steeda Superlite Springs and 03 cobra front lca with 94+ Tokico HP struts/shocks
Before: I had a fairly high stance as well
L
LAFENATU
Love it.
Looks awesome. Did your car sit as high as mine does??
wytstang
LAFENATU said:
Love it.
It didn't look as bad due to the 18's but yeah it had a lift that I lived with for a while.
Before:
After:
Spd0lit
SoCal
Yea i have a c-spring/with strange adj. i like the stance just right for me.
L
LAFENATU
I was going to do those but the guys at MM said they would be a little obnoxious for a DD.
GDTrumbo
Nashville, TN
This one seems to sit abnormally high. Are the springs not "clocked" correctly or something??
GT
Rawb, do prokit and tokico blues.IMO Best bang for the buck.
Codycougar91
The H&R's are pretty bumpy, but i like them a lot on every car ive been in/around with em
Suprasuavy
