wheel help
Austinx56
Austinx56
Daphne Alabama
is it bad to go with 10.5 in the front?
more then likely im going with 9 on front and 10 on rear i was just wondering
Yeah, that's too big.
You're going to have to run at least a 295 tire in the front, which will look ridiculous.
Unless you have a track car where you need maximum contact with the road, 10.5 is unnecessary.
You can run 275s all around with minimal suspension work, but 275 isn't for a 10.5" wheel.
mikey94gt
Can you say fender flares? or a bit of chopping at least? I run an 18X9 in the front on the street, and its flush with the edge of the fenderwell. a 10.5 would probably be 3/4" to 1" out, depending on the backspacing and such..... we wont talk about turning radius yet... haha
If you're going to get Saleen's, get 18's. 17's look out of proportion.
ivan12
245s on a 10.5" wide wheel? No
http://i471.photobucket.com/albums/rr72/jorgealvarez_rt/Oboyhahahaha.jpg
2v_takeover
Saskatchewan
I think you're going to hate yourself if you don't go 18's. They seem to fit the wheel wells so much better than 17's, especially in Saleen's. Saleen's look the best in 18's. And you're def not going to fit a 245 on a 10.5 inch rim.
Musturd
Do burnouts problem solved and settle with 18's
96TANGERINEGT
Wow. 10.5 on the front , now that would be kinda cool . Just run drag radials all the way around like 285. Up front then go like 315 on the rear. That would handle like a mofoooooo ,,
Marvin97
Glasgow, Ky
I have 17' saleens on mine, I think they look fine?
Walking Tall
Middle TN
Sell your tires and get 18s. Wheel Replicas has a set on 18x9 18x10 polished for about $550 shipped.
g36 monkey
Orlando, Fl
I do agree Saleens ought to be 18's, and this is coming from a die hard 17" dood.
However, you can put the 245 on a 9" tire, and the stretch is not noticeable. Note some of my pictures. On a 10 or 10.5, you would be approaching hellaflush.
No.
peasant99
