I just finished swapping an 03 Cobra rad into a 96 Cobra without the cooling update.
i was able to use 3 of the 4 mounts...
Here is how I did it:
-Reuse the top left rad mount by flipping it/cutting it/notching it and using a spacer plate to bolt to the rad support....
-Reuse the top right mount(but it needs to be shorted in height a little bit(but will still fit without modification.) I'll cut and weld it at my friends house alter, but for now it works just dandy.
-Insert the bottom right mount(by the ABS hardware) into its rubber mounting point.... Simple
-Finally the left lower mount just hangs off the side of the original tab on the rad support but it is held securely in place by the lower hose...
It took me about 6 hours to do this working slowly and carefully cutting/notching/drilling little aluminum spacers to make the mounts work...
The car now runs cooler than it did with the 180deg 03 Cobra tstat, and the bigger rad.
NOW I have only one q(not to thread jack
Does anyone know where I could get a newer style rad fan harness plug from an 03/04 Cobra? The new rad fan has a new style plug which is ROUND so i cant use the new fan until i find a male connector for it...
Hope this helped some of you.
Cheers! :headbang:
