03 avaitor what can i get from it
jarad302
there is an 03 avaitor at the junk yard i work at if the heads have the correct casting number what else could i use from it for a terminator top end swap
Mystic SVT
just the heads and valve covers I believe. I'd stick with the 96-98 B-head cams if you have this yr cobra. I don't think theres much else you can use off the aviator motor for an eaton swap. Timing covers are different and no use for the intake (you don't want this intake anyway).
Mystic SVT
massacre said:
^^^ Why?
...Just curious...
96-98 cobra intake cams are the most aggressive out of all the 4v cams from 96-04. The exhaust cams are the same from 96-04 in cobras and mach1's. Navigators and aviators have different specs on the cams I believe which are designed for optimum power in the lower rpm range.
When swapping to 99-04 C-heads it is recommended to stick with the 96-98 cams if staying n/a
alleghenyamerican
Staff online
