1996 GT PATS trouble
Corey Vitatoe
Austin, Texas
Hi,
My name is Corey, I'm new to the forum and looking for pats help! I have a '96 gt convertible and I'd like to try to figure out why it's not reading the key.
The Story
I was suffering from denial. I have a 94 f150 running a 351 with ported heads, intake, long tubes, true dual, 4 inch lift, 33in A/Ts, and a few other goodies... and a certain lead footed driver. I was certain I was getting 30 mpg driving all over Texas. Turns out my estimate was slightly off.
I have since come to accept that honesty with ones self is important. I decided I needed a more efficient vehicle. While shopping around I found the perfect solution! A brand new to me 1996 gt convertible! (3x the mpg!) I talked the seller down to $400 because it didn't start and they couldn't figure it out. (In my head, at $400 I could get it and swap in a 302 if I got tired of messing around with the 4.6.) The only thing is the car doesn't run and the theft light flashes.
What I have tried.
At first the car wouldn't turn over, and the fan was constantly running. Figured that out and swapped the CCRM for one that I know works. Something still wasn't right and I pulled the ecm to have a look at it and found out it was for a crown vic with an automatic. -_-
Swapped in a proper ecm, put in a new fuel pump and a good test battery. Everything seems to be working well, the car even turns on and runs for a second. However the car won't stay on and the theft light flashes. After some digging I believe it's the PATS.
I have tried swapping the transciever and the pats unit itself, I have had a locksmith out with a full diagnostic system, tried different keys, all to no avail.
From what I know thus far...
The PATS (Which is type A) is not reading a key. *Note: NOT THAT IT SEES THE WRONG KEY BUT THAT IT DOESN'T SEE A KEY AT ALL. From my research I can tell that it sees no key because the light doesn't flash for 15 minutes (so I can't reprogram it). It only flashes for 60 seconds.
I don't want to need an SCT tuner to use my car at all, but I will if I have to. I have searched so much for the last 7 months and have found no real information for how to address this specific problem. I was wondering if there is anyone that can help me out.
C
Corey Vitatoe
Austin, Texas
Also, there is this unmarked box in the center console. It appears to be an aftermarket install of some sort...
07GtS197
Fort Myers, Fl
If you know someone with a scanner or an sct tuner have them come over to read the codes. Otherwise you could buy one pretty cheap. Even pats faults will throw codes.
That box looks like a speedcal or something. My 02 gt has one but I dont remember all those wires coming off it though I wasnt the one who installed it.
