4v supercharged, how much Hp?
NERD
Virginia
I'm having a delema....
What makes more Hp, a forged 4v with 15lbs of boost or a forged, cammed and headed 2v pushing the same boost?
NERD
NERD
Virginia
How much hp does a Cobra make at 15lbs of boost?
bigjohnson4.6gt
well the thing is, they are both going to be around the same hp na, but when you add boost they are probably going to respond differently. Im not sure how much the cobra would make at around 15lbs of boost. You would have to do some in depth research to find out which one would be the best bang.
NERD
NERD
Virginia
A 98 would normally dyno at around 280-290rwhp and the my GT dyno'd at 260rwhp NA. With my V2 my 2v made an awesome 17rwhp per lb of boost. Does the math work the same for the better flowing heads on a 4v?
I guess another great quest really would be, Will a V2 hit 15lbs of boost without over spinning?
justinschmidt1
Whatever makes more power before the blower should make more power after.
Honestly, it should be about the same....but my money would be on the 2v since it should make more power with H/C than the 4v will stock and should flow better.
mellor_21
he's right, boost will just add more air, and therefore more fuel so long as your system can supply the fuel and air, but the way i think of it is.. your most likely never gonna stop trying for more, so in this same setup you could later on improve your h/c/i on the cobra and make even that much more.. whereas on the gt your kinda stuck on what you've got you know?
uncltrvlnmatt
Pa.
MarcInJapan's Terminator is pushing about 15lbs of boost and is just under 500rwhp. If I remember right he is still useing the Eaton.
snoball
My buddy with a 96 cobra , stock motor besides fuel,tune,longtubes,imrc deletes and tb made right at 490 to the wheels on 15lbs through a v2.
mellor_21
(0.5 X CID X Rpm / 1728) X VE X DR X .069 = power
(0.5 X 281 X 6100 / 1728) X .85 X (i forgot what dr is haha) X .069
anyway when i figured this out awhile ago it came out that turbos would make about 560 to the flywheel at 15# :) +1 turbos
jumperjack
15 lbs. w/ Kenne Bell 2.6H
http://www.youtube.com/watch?v=yXCTKaQgrx4
snoball
I must say you are the first one ive seen to put a kb on an sn 4v car besides one guy locally with like a 1.5 on it. good numbers though.
TxCobrA98
the Vortech V2 im buying tomorrow has a 12-14 lb pulley on it and the guy that owns it right now has a forged motor and ported heads along with cams and made 620hp.
Fl510
