94 GT help.
shock357
I finally started working on my project car again. All the problems started about 2 years ago. Took it on a 500 mile trip, everything ran great. Left it idling as I ran into the store to grab a drink. Hopped back in and went to take off and it fell flat on its face. Studdering and backfiring t anything other than light throttle. Limped it home and it's sat in the garage until about 4 months ago when I finally started to play with it again.
Here is a video of what it is doing (please excuse the crappy camera work)
http://i18.photobucket.com/albums/b...E0E263E-1148-0000022D0A915AB0_zpsb6e235d8.mp4
http://i18.photobucket.com/albums/b...F7F22A0-1148-0000022CF6EFA7A0_zps03104b0d.mp4
The motor is a stock bottem end. 40p heads. B cam. Trickflow intake. O/r x into 40s. Mail order tune from DDR.
In the last 4 months I've changed the following
Fuel pump - bbk
Fuel filter - oem
Pip - oem
Cap rotor plugs
Injectors - venom 24s
02 sensors - oem
Coil - msd
Tune - DDR racing for 24s head combo and egr delete
Maf - oem
Iac and tps - oem
Injector harness ( old one was hacked into)
Car has no codes showing
I'm at a stand still on what it could be now. My next step would be Mach timing jumped some how. But it starts right up and idles fine. Anyone have any ideas?
Thanks.
RichV
CO
I would check the tps. Vacuum leaks and grounds would be 2nd.
have you verified fuel pressure? Last, ECU or tune/chip. Do you have a spare ecu?
