94 mustang gt with kenne bell belt path
MasterDot
Washington state
Hello I have a 94 mustang gt with a kenne bell, and 93 Fox accessories, I currently have my belt on, but it's rubbing under my tensioner, can I route it a different way? Red is currently what I have, green I'm thinking I can do, I have the pulley tensioner for the KB just not pictured no sure if the belt should go under the idle pulley and then up to the KB or if it should go over the KB and then down under the idler and then to Ps. All help is appreciated!
MICHAEL PENDRISS
View attachment 49037View attachment 49038View attachment 49039
I believe the red is the one you want, I will have to look at mine when I get home from work to verify.
Procharged87
You need to be using the Kenne Bell idler also. At least half of the KB pulley should be covered by belt or you’re likely to get slippage. It should come off the PS pump and go under the KB idler, then back around the KB pulley and down towards your alt/idler from there. Mine still has the 95 accessories so mine goes from KB pulley to alternator, then to the idler, then smog wheel, over water pump, around crank, to A/C, then PS, then KB idler.
Bootsie
