Brembo nutswinger custom 4 piston rear caliper Cobra IRS install almost done
<blockquote data-quote="96blak54" data-source="post: 1587604" data-attributes="member: 14727"><p>Here you see a tsx Acura with the big genisis brake caliper and nissan rogue big rotor from a 3rd row seating rouge(specific 3rd row seating nissan rouge)</p><p></p><p>The reason im jumping on this is because the acura rotor and the stock 96 mustang gt rotor are identical minus the hub bore i.d. and the overall diameter. The acura hub bore is smaller and the overall diameter is bigger, but relative location center to the caliper is identical along with the 5x4.5 bolt pattern.....with that said ......and so is the nissan rouge 3rd row seating rotor. The nissan rouge rotor is 13inch o.d. Its not a problem increasing hub bore diameters that would be needed to the acura/rouge rotor to allow them to slip on.</p><p></p><p>The stock mustang spindle caliper mounting holes are 5.125" center/center while the hyundai genisis 4 piston caliper is roughly 5.500".....iirc. I need to measure and write down these numbers, but you guys see there is a possibility for an awesome brake upgrade on the cheap.</p></blockquote><p></p>
[QUOTE="96blak54, post: 1587604, member: 14727"] Here you see a tsx Acura with the big genisis brake caliper and nissan rogue big rotor from a 3rd row seating rouge(specific 3rd row seating nissan rouge) The reason im jumping on this is because the acura rotor and the stock 96 mustang gt rotor are identical minus the hub bore i.d. and the overall diameter. The acura hub bore is smaller and the overall diameter is bigger, but relative location center to the caliper is identical along with the 5x4.5 bolt pattern.....with that said ......and so is the nissan rouge 3rd row seating rotor. The nissan rouge rotor is 13inch o.d. Its not a problem increasing hub bore diameters that would be needed to the acura/rouge rotor to allow them to slip on. The stock mustang spindle caliper mounting holes are 5.125" center/center while the hyundai genisis 4 piston caliper is roughly 5.500".....iirc. I need to measure and write down these numbers, but you guys see there is a possibility for an awesome brake upgrade on the cheap. [/QUOTE]
Latest: 07GtS197
16 minutes ago
Build Ups & Projects
96blak54 2001 Cobra
Latest: 07GtS197
18 minutes ago
Latest: SsgDoc94
Today at 7:44 PM
Latest: 96blak54
Today at 5:39 PM
96-04 - 4V Specific
Latest: ttocs
Today at 5:23 PM
Jerry santos
