Well I'll jump in here! Well the reason people are bashing on the alphabet cams is because anyone who knows things about duration, overlap and lift, knows that a cam that has the same lift and duration for the intake and exhaust is not going to make power like a cam with dual pattern lift duration favoring the exhaust. Just a fact. I have had B cams, E cams, F cams, and had a few X cams on the dyno. They sound nice, pick up a little bit of power and some work well with blower apps, but then so does a stocker.
I grind custom cams, no I don't go out to my million dollar machine in my back yard and grind a cam, rather I do what all the big name guys do, go through the hundreds of lobe profiles and choose combinations that will work well with certain engine combinations or someone's specific engine combo, and then have a camshaft company grind it for me. I go with a top name grinder because I believe the quality of the camshaft and their cnc lobes are excellent. And NO, I am not advertising, just qualifying myself.
Now back to the discussion, with stock intake and heads, no cam will make more power in the midrange and top end that I know of. Most camshafts open the valves up too much in those stock heads that stop flowing at .440 lift, so opening them up farther causes the air to tumble and you'll get a howling, rumbling noise on the flow bench. I have done a lot of work with stock heads, flowing them and developing a port design that I went 10.0X with on nitrous and a stock cam, yeah, stock. Nothing works better with stock heads than that camshaft.
Now, the ONLY camshaft I have found(and I didn't look very hard) that will make a little more power, or at least should, with stock heads is the b cam. It has very low lift, more duration and has tight LSA. BUT, you will need better valve springs to work with ANY camshaft you put into it.
If you do plan for sure without a doubt to buy aftermarket heads and intake down the road, the stage 1 TFS cannot be beat for the money. If you want to make power with the stock heads, that cam will probably not do it. It will sound good tho.
