Cam upgrade question
Corndiddly
Collins, WI
Well when I bought the car I was told it had a cam. I just pulled the cam and miced it and came up with .444" lift, so it's stock. What's a good cam to upgrade to? I have a edelbrock upper and lower intake. Crappy ebay CAI, long tubes with a off road x pipe.
white95
Apex Junky
Admin
Prairieville, LA
Short answer:
1) Steeda #19 [works well with the stock tune]
2) Trick Flow Stage 1 [can work with the stock tune]
3) FRPP E-303 [hit or miss, mine worked with the stock tune but idled funky]
4) Can also install 1.7 roller rockers to the stock cam for a nice gain instead of a cam swap!!
Corndiddly
Corndiddly
Collins, WI
Any pluses going with 1.7 and stock cam over let's say the trick flow stage 1? I like the idea of putting a fresh cam in over putting the old one back in.
Addermk2
do not run an E303 cam.
Honestly, if you have stock heads, an aftermarket camshaft is a waste of time.
white95
Apex Junky
Admin
Prairieville, LA
Addermk2 is more knowledgable on this topic but when you use 1.7 rockers with the stock cam it effectively raises the lift at the valve. Right?
Also, the OP has another thread asking about upgrading the heads to AFR 165 (or something similar in 1.90/1.60) status. Hopefully he wont try to put "lipstick on a pig" by putting an aftermarket cam with the E7 heads.
Corndiddly
Corndiddly
Collins, WI
Would it hurt to put a cam in though? I may not gain any power, but when I do upgrade my heads I don't have to worry about putting one in then. My stock cam has maybe 150 to 160,000 miles on it.
whiplash473
Northern IL
Problem is you're cam selection is limited now with stock heads..and when you put new heads on you'll probably wanna upgrade
Sent from bored/stroked iPhone
whiplash473
Northern IL
I'd throw in a trick flow stage 1..there's a lot of choices and opinions tho
Addermk2
I would be more inclined to believe that you measured a 0.277" difference between peak lobe height and base circle diameter.
Rocker arm "ratios" are a multiplier of the cam lift. The measured valve lift of a stock cam is .444" with a 1.6 rocker. The cam lift is actually only 0.277". When using a set of 1.7 rockers, you new measured valve lift should be ~0.472".
Makes sense. What would be a good cam with my set up and trick flow 170cc heads
TFS stage 2 and notch the pistons for valve clearance.
white95
Apex Junky
Admin
Prairieville, LA
Addermk2
LOL, you don't need new pistons big guy. You just need to notch what you've got.
