changing bodys?
jarad302
my 96 cobra is done i need a new body i was thinking of getting a new edge body a putting all of my cobra stuff into it im just wondering it the tranny mounts are the same and if i can put my k member in the new body
ProKiller
PA
whats the matter that you say the body is done? everything should bolt right up though as its pretty much the same car.
J
jarad302
quater panel trunk rear bumper bumper support roof is buckled floor pan is buckled frame is bent door over laps now when shut its super f***** up lol
castine917
wyoming, mi
take as many good parts from your messed up one as you can including wiring. wiring harnesses may be different but, where the k-member, trans, and many other things bolt in will match.
rz5.0
Great state of TEXAS
All the mounting points are the same some of the wiring is diffrent. Not sure on the fuel I know some use a returnless fuel system
sounds like a lot of work and when you are done you will have a double clone since not only is it not a cobra but not a new edge. I guess it would be an interesting conversation piece but it just sounds like alot of work for????
98zzzz
do it! Its not alot of work, its just time consuming. Stay patient, drink beer.
<br>
and 99 up cars use returnless fuel system??... that will be some work.
ProKiller
PA
i think you'd be better off getting a new shell and just transferring over your stuff.
time consuming
well if time = money then time consuming = money consuming
Now along those same lines:
women = time x money
time = money as we already proven so then women = money x money = money ^2 right
now we all know that money is the root of all evil right?
take the sqaure root of money then and you can there for prove that women = evil :)
for those of you that have not seen:
http://www.google.com/imgres?imgurl...a=X&ei=A4j2TcWDBuun0AGWo9jrDA&ved=0CDEQ9QEwBQ
J
jarad302
i want to keep a 4v and my credit is shot so me getting a new car is out of the question unless its like a beater i already plan on switching the fuel system because i have everyting to do a c head swap, i was already planning to swap everything to a 94-95 body so i dont have to go threw emissions but i love the new edge and havent had that body stlye yet so i was jw if it was a headache
J
jarad302
things like front lower controle arms and brake lines fuel lines steering shaft, i was already gunna completly strip one car and use all my wiring what i ran into was what about the different head lights and tail lights can i use my tranny crossmember would i have to get a gt tail shaft housing for my tranny or do i have to get a t3650 will the heater core match lol lots of things im unsure of
19mustang95
The transmission mounting points on a new edge are far different from a SN95. The k-members are the same. The control arms bolts are different sizes. I know the dash wiring harness is different, not sure if the engine harness can plug straight into the car. You can always use the harness that comes with the car if it is a GT or Cobra.
castine917
wyoming, mi
your right on cross member being different on mounting method. i forgot. my bad.
