climate control switch problem - only high setting
boss281
My climate control fan switch only has one speed working (the high speed). None of the others work. I had a similar problem once where only the defrost mode worked but that was a vacuum line came undone. I checked the vacuum line and it appears fine. Any ideas?
Is there an online shop guide anywhere?
John
GDTrumbo
Nashville, TN
Supposed to be online service manuals at the top of the page here where you started this thread.
Could be a simple harness connector with moisture problem under the hood.
GT
B
boss281
Well, I'll start troubleshooting this weekend. The online manuals referenced in that thread by the way are no longer available...
B
boss281
karrarararararar said:
it's your blower motor resistor. it's located right behind your glove box next to the blower motor
Ah. I JUST replaced the blower motor--wonder if that's related. Either way thanks, I'll pick one up today if I can and put it in Saturday.
I appreciate the feedback.
John
