For Sale Clist find, 03-04 IRS louisville ky $1000
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Dont forget, you will need the brackets that bolt to frame in the rear, youll need 14mm bolts for the front so youll have to drill the car out to 14mm. Then you will either drill and bolt the verticle bolts for the rear bracket or weld that to the subframe. Then you have to build the two rear brake lines going to the calipers.
Oh and make sure the pinion flange is correct for your driveshaft. The cobras had a larger flange.
evilcw311
Most Evil Member!
Louisville, KY
Hopefully I can find out those rear brackets cause I don't see them in the pics. He doesn't have all of the bolts so I'll have to source those as well. Do you have pics as to how most have done their brakes??
And I'll be getting a new aluminum driveshaft as this car is going t56 magnum so I'll talk with dd performance when I order my tranny kit from them.
lwarrior1016
Staff member
South Mississippi
Full tilt boogie racing is the place to get ALL of your IRS needs lol. Check in my build thread, I have pictures of my lines when I made them up.
D3VST8R96GT
Marble Fall, AZ
Those brackets are getting hard to find. Most people don't pull them off when they pull the IRS. They aren't that crazy to fab up though with some pics for reference
evilcw311
Most Evil Member!
Louisville, KY
Pics, part numbers, actual name of said brackets?? Anything you can provide will b much appreciated
Is that what your talking about??
lwarrior1016
Staff member
South Mississippi
That bracket "kit" isnt the actual bracket. That is just the steel plate that you weld to the top of the bracket.
cheebs127
Waldorf, MD
I have these bolts that I didn't use that came with my IRS. If you ended up needing any of them. I believe the longer ones are the forward and aft cradle mounting bolts
evilcw311
Most Evil Member!
Louisville, KY
I got the cobra brakes with it but no bolts. How much you want for those??
