94StewFord
I have my '94 GT that I purchased last fall. 37K original miles, automatic. It wasn't used much the last few years by the original owner, but it drove home 10 hrs like a champ. No noticeable drips inspecting on arrival, changed the oil a few weeks later. However, there was a build up where the transmission meets the motor around the inspection cover. Now I see since it's been sitting over winter ( I start it up once or twice a month and let idle) there is something leaking near the same spot.
I need to get the car up in the air in the spring to investigate, but figured I would as what are the most common areas to look for. I am assuming worse case rear main seal, then the obvious oil pan, valve cover.
Thanks for the input!!!
