Factory CD player (non-Mach)
jojo22
So on my way to work everything worked fine, got in her to drive home and the CD player wouldn't power up. looked at the fuse diagram in the manual and only say one "radio" fuse, and I'm sure it's fine because AM/FM works fine, just no CD action.
Any Ideas??
don't even bother with the manual for fuses. Just go in and start on one side/corner and work your way down until you have checked every fuse. This will take less time then sorting through the manual, and also ensure that all the fuses are good. You would be amazed how often the fuse blown has nothing similar listed in the manual. Also don't forget the fuses under the hood.
J
jojo22
Thanks, I pulled her in the garage for the night and there's not much light, but tomorrow after work I'll check them all and see how they look.
J
jojo22
All fuses are good! Side note, do we have a light on the dash to tell us cruise is on? If so mines not working, just thought I'd throw it out there as a possible symptom.
J
jojo22
yep all where good (didn't check the giant ones though), also when I turn on the headlights the CD player lights up, just no display or sound
J
jojo22
And now I don't get barely any sound from my 12 disk changer (the type that goes on an FM station), hoping I don't have bad wires in there for some reason, but the 12 disk is the only after market gear in the car.
