fog light mod
US Soldier(stang 98)
Dixon IL
i cant find the right up for the fog light mod. how do i get my fog lights to come on with my running lights? thanks guys
Orange Stang
disclaimer, thats not the writeup i used. mine was out of some sn95 muistang mod book which i cant find.
ryclef331
under the console is the harness for the convertible top. It will be an unused plug in that WOULD go to the top switch if you had a drop top. Not sure the wire color but all you gotta do is find the 12v+ wire on that, tap into it and run it to what would be the 12v+ source for when the headlights are on on the fog light switch harness. Its all in the console.
bsn95w
did new edges come this way? cause my 00 does it already.
If you want the fog lights to come on with your parking lights the wire swap is simple, takes no cutting or splicing at all. It's just a matter of switching two wires in the harness. If you want them to be active any time the ignition is on then wire them to the convert top power.
yes.
Monday
The issue I see is with the Convertible's power supply, the E-brake must be engaged...
peasant99
