Got my new springs!
sn95jones
Arlington, Tx
On my way back from the meet last night my buddy offered to install my springs so I stopped by! New springs look amazing but shit its a bumpy ride!!
Time for some wider tires and blacked out tail lights
ReplicaR
Good god, looks like you are completely on bumpstop. That's not a complement btw.
Paul
Dang, that's low. What kind of springs are those? Do you have isolators in there?
robb15033
Northern Va.
Be watchfull & careful of tire wear and propper cornering control. If the ride is bumpy (bouncy?) new struts/shocks will firm it up. The guy "ReplicaR" helped me with my questions as I tweeked my suspension. Enjoy.
Mystic SVT
It looks good but honestly your ride will only get worse, you have changed the spring's rates drastically with cutting off so much material to go that low. If you would have cut only one coil off each spring then you would still be ok but from the looks of it it looks like you guys cut off at least 2 coils on each spring.
sn95jones
sn95jones
Arlington, Tx
Yeah I've got brand new struts and shocks along with brand new bushings and ball joints, just had them installed about 2500 miles ago if that.
And yeah its got a very firm ride and to be honest I like it, I know it throws me around a bit but hey a muscle car is not meant to ride like a Cadillac. Yesterday I took an off ramp that looped around to my road and I took it at about 50mph and the car didn't budge one bit, it held its ground very well.
Looks good.. but man thats LOOOOW
If you decide to keep the springs, get some cc plates and make sure you get an alignment ASAP!
ReplicaR
The shocks are not the solution to having a better ride here. My guess is that the car is too low, and you probably riding on bumpstops at this moment. It may not sound like a big issue to you, but every time you hit the bump stop, you end up going almost solid in that corner which is what contributing to your harsh ride. On top of this, not only is your ride height it compromised, but so is your handling. Every time you ride the bump stop, your spring rate becomes infinite, because you are solid to solid surface. This means that if you hit the rear bump stop in the middle of the corner, you end up going much stiffer in the rear, and that will cause the car to oversteer. Suspension should never bottom out, if you want it to work properly. There has to be a certain amount of suspension travel and weight transfer depending on what kind of tire you are using. The less weight transfer you have, the stickier tire has to be to compensate for it. Those people who lower their cars right down to bumpstops, and think that their cars handle great due to no body roll because suspension has no travel, are deeply mistaking.
framda
Naples, Fl.
Wait till you hit a bump at 50 MPH in a corner and you go airborne
