heads,cam,and intake valve size question
coupe5ohh
Phoenix, Arizona, United States
sup guys i got a set of ported windsor jr heads for 80 bucks cause a friend was putting on his afr 185s..so i have 1 question(when i say one it will most likly turn into a bunch) the heads have a bigger intake valve 2.02 and i was wondering if ill have p2v clearance issues with 1.6rr and a tfs1 cam
hottwheels04
1st off $80!! lol dam @ that price he should of just gave them to you for free such a random extreme low price for heads that cost $500-$1000+ lol and 2nd you have to check your clerance, and with such a small cam you should have no problems!
C
coupe5ohh
lol it was actually a trade i had a extra set of poly motor mounts that cost me like 80 bucks nd he needed em so he was like wanna trade?i was gonna buy em frm him anyways
mattm
Im sure someone will disagree but u shouldn have any issues!!! i have run edelbrock, trickflow, n afr heads on various cars. All with 202 valves never had a issue with em as far as clearance till i tried runnin a x 303 cam n tried degreein it then it was extreemly close, Good idea to check but highly unlikly it will be a issue think u will need to run head bolt bushings with them though 302 is 7/16 head bolts 351 is 1/2 head bolts
NXcoupe
If it is a stock piston engine, a 2.02 valve will be very close if not hit with a .500 lift camshaft. It is easy enough to rent a notching tool and notch the pistons. Use a shop vac to get all the aluminum filings out of the cylinders.
Jerry santos
