HELP NEEDED!
  • Thread starter FullThrottleStangs
  • Start date
F
FullThrottleStangs
Guest
Hey guys i got the codes read last night at autozone and i have a missfire in cylinder 7. i have found out which cylinder that is and my father and i are looking for the spark plugs to see if there is just a simple problem with them... but they are nowhere to be found. any ideas? i really need help on this.
atlanticblue98
you dont know where the spark plugs are? or you want advice on other simple causes?
F
FullThrottleStangs
Guest
i want to find out where the spark plugs are. as for other causes, more suggestions wouldnt hurt i guess.
atlanticblue98
they are underneath the COP cover. remove the cover, the remove each Coil. each coil is covering a spark plug
F
FullThrottleStangs
Guest
sorry replied before yours appeared i guess. well thanks for the help man! :thumbsup:
gt96stang
My suggestion for you is to pick up a chilton/haynes.... It'll help you a good bit for the basic stuff.
spark plugs are under the cover on each vlave cover. check the cylinder's plug and coil. check the gap as well.
duff daddy
MustangChris said:
Duff Daddy said:
plugwires > cop's
reasons and evidence for this claim?
life experience... ive seen ALOT more issues with coil on plugs (cops) and if you have worn plug wires you can see the issue ie worn insulation, arcing, cut, knicked ect and alot cheaper to replace a set of plug wires then 1 or 2 cop's. also with the solid coil packs mounted on the front if you do need to replace them, its alot easier then it is on some vehicles. my experince they seem to have alot less issues with them then cops.
**** yes i know with cops its easy to swap from one cylinder to another, i still would wrather have the wire setup then cops****
I know this is chrysler experience, but in 4 years of at least 60 cars in the shop a day, i think ive replaced MAYBE 4 coil packs.... and prob about 50 cops? hell even the beloved 4.0 has cops and it SUCKS. why do you think on hemi's (very very reliable engine) they use a wire set up even with 16 spark plugs?
