Help! No crank issue
WillC
So I just put a new engine in my car and when I go to start it I get no crank and the only light I get on the dash is the airbag light. My battery is good and all interior/ exterior lights work. Idk if it’s a wiring problem or not.
07GtS197
Fort Myers, Fl
Can you give us more info on the car? Auto or manual? Without more info I’d suggest checking all the fuses first.
07GtS197
Fort Myers, Fl
I’d look at the clutch position sensor first to make sure it’s functioning. It could be malfunctioning making the ecu think the clutch isn’t pushed in all the way.
W
WillC
I replaced it 2 days ago and I still get nothing
W
WillC
Also when I try to turn it over it makes a little click noise. I bolted my power strap to the motor mount so idk if that could be the issue or not
07GtS197
Fort Myers, Fl
If it makes a single click, it could be a drained battery, starter solenoid sticking or even an improperly indexed starter. What are you referring to as the power strap? If it’s the engine ground I think that’s where it goes.
W
WillC
There’s a red strap connected to the frame and a black one coming off the harness and I have them both bolted on to the motor mount but on separate bolts
test the voltage at the starter while cranking. And while you are down there give it a thump with a wrench/hammer/ect.
W
WillC
I’m getting 12.4 volts to the starter so it is getting power
W
WillC
Does it matter what stud I put the positive and negative wires on for the starter
