Highlighted posts from Friday, Dec. 31, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
December 30, 2021 * 29 posts * 269 views
Jp6.0 said: I'm probably sucking more air than some of y'all, but having my filter in the fender is awful. It gets so dirty it ain't even funny. I bet I clean it every 500-1k miles. I even ... Read more >>
December 30, 2021 * 5 posts * 31 views
Katstang said: Ok so I had acquired a 98 gt coupe, needed the tranny fixed or replaced, a few months later I ended up buying a 98 gt vert, it runs, but my problem is this, after I got the 2 98 ... Read more >>
December 30, 2021 * 6 posts * 78 views
95opal said: Weld in your subframes bolting them in isnt as effective. Read more >>
December 31, 2021 * 7 posts * 102 views
Gregomatic said: White, I've been back to that link to soak up some more knowledge about diff's. The rear differential on my car is letting me know that replacement is becoming less of an option ... Read more >>
December 31, 2021 * 1 post * 18 views
RufusT said: I just replaced the ECU in my 1994 Mustang GT. I'll save the details for another time. When I started it up, after installing the new ECU and the machine would not idle down. It ... Read more >>
December 30, 2021 * 74 posts * 715 views
chrisp427 said: Distributor has power but the coil does not. I put the multi meter on the coil power wire while cranking and got nothing. This wire runs straight to the FAST ignition box which ... Read more >>
December 31, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Cold Air Intakes.................. December 30, 2021 * 20 posts * 143 views 94-95 5.0 - Specific Chassis matters... December 29, ... Read more >>
December 30, 2021 * 82 posts * 837 views
Jason.Silus said: Managed to jump start it a few minutes ago, feeling blessed that I don't have to install a new starter. Unfortunately, the car is dying after revving passed 3,000 rpm, and then ... Read more >>
Continue reading...
