Highlighted posts from Friday, Feb. 25, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 24, 2022 * 22 posts * 178 views
Monday said: Is there anyway a body shop can pull the front of that clip over? The guy from "Graveyard Cars" always tries to save the original steel and only chucks stuff if it absolutely cannot ... Read more >>
February 24, 2022 * 12 posts * 91 views
ttocs said: they do not need to be off far enough for your eye to see to be able to throw the belt. Its possible the brackets are loose or possibly cracked and flexing when you have it under ... Read more >>
February 24, 2022 * 6 posts * 33 views
94StewFord said: So, the two screws appear to be Torx, but none of mine fit????? Read more >>
February 25, 2022 * 18 posts * 164 views
Notthenow said: Hey Blak, I assume Mahle is in spec as it's Fel Pro's cousin company? Read more >>
February 24, 2022 * 4 posts * 26 views
Duff said: I'm changing out springs soon, and wondered if anyone leaves out the spring isolators, I think mine are in bad shape or even missing. ( I haven't checked it too closely). Read more >>
February 25, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Can I use 95v6 parts tot repair my 95gt front end damage? February 23, 2022 * 18 posts * 127 views Exterior and Interior Belt alignment ... Read more >>
Continue reading...
