SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
July 08, 2021 * 12 posts * 98 views
Chip Schweiss said: I've heard lots of troubles with the McLeod hydraulic conversions. Usually, the slave cylinder leaking. If you are getting blocked out of gears, the clutch is not disengaging completely. ... Read more >>
July 08, 2021 * 7 posts * 60 views
lwarrior1016 said: That's an electronic controlled transmission, you'll need the ecu to control that. When you install the 289, it's going to remove critical sensors that the ecu needs to see for ... Read more >>
July 09, 2021 * 2 posts * 10 views
markmopar said: Hey all, I recently got myself an 01 GT. It has 192k on it and starts to smoke after it idles for a few minutes so I assume the valve guides are shot. The trans shudders going ... Read more >>
CampTheChamp said: While the car is running the highbeams won't turn on, and no light on dash. However when the car is off in park the highbeams work fine, but no light still. Not sure what the issue ... Read more >>
July 09, 2021 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Anyone Know What Wheels These Are ? July 07, 2021 * 18 posts * 183 views General Tech Hydraulic Clutch issues July 07, 2021 * 9 ... Read more >>
Continue reading...
