Highlighted posts from Friday, Jun. 18, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
June 18, 2021 * 14 posts * 100 views
96blak54 said: Here is my take based on this info. When it comes to a street cruiser, performance really doesnt matter and i state it like this because the car is more of show and tell than it ... Read more >>
June 17, 2021 * 11 posts * 47 views
Chenn2389 said: There are only a few things left to check. Something has to be back feeding the light blue with red stripe wire after the fuse box. The only things I haven't checked that could ... Read more >>
June 18, 2021 * 14 posts * 146 views
96blak54 said: Whatever the suggested oil capacity is, youll find your first oil fill up will be more because the engine was dry. Starting at 5quarts is good. Then youll discover later after ... Read more >>
June 18, 2021 * 3 posts * 37 views
Flade said: Find a GT in the junk yard and just take all the parts and wiring. Straight bolt in job. If I remember correctly, two lights & brackets, wiring harness, switch, power relay. Read more >>
June 18, 2021 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Cam thoughts inside please! June 16, 2021 * 8 posts * 41 views General Tech Oil change questions; just making sure! June 16, 2021 ... Read more >>
June 18, 2021 * 12 posts * 260 views
96blak54 said: All the cam towers of a modular head have oil ports and is connected straight to the oiling system with no orifice unlike the hydraulic lashers which are regulated and on an orifice ... Read more >>
Continue reading...
96Mustang4.6GT
