SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
March 17, 2022 * 25 posts * 175 views
TrickVert said: I would only consider long tubes if you're looking to take advantage of other performance mods (H/C/I, for instance). LT's will cost more for no performance gain (or almost none), ... Read more >>
March 17, 2022 * 8 posts * 86 views
joemomma said: LOL! I'll never tell. In all seriousness, it's on FB Marketplace. I need to do some checking first. I'm not sure how well a 158k mile stock 302 would handle any sort of boost. Read more >>
March 17, 2022 * 5 posts * 39 views
Booboo said: 1997 GT 4.6l. I just replaced all the O2 sensors, plugs, wires and coils. It still isn't running right. It is running a little rough and sluggish. It hesitates a little when floored. ... Read more >>
March 17, 2022 * 13 posts * 133 views
Monday said: Well, I got the bolt out. Thanks for all the replies. Every one of them. You were all very encouraging!!PS I also found out from the "Idea Guy" (exhaust guy whom suggested ... Read more >>
March 18, 2022 * 3 posts * 13 views
Monday said: I tried to install my new crank damper today and it just wouldn't go on. Has anyone dealt with this? Pretty sure "Yes" Do you have a trick, tip to share? It's a PowerBond by Dayco: ... Read more >>
March 17, 2022 * 43 posts * 226 views
ttocs said: if I am reading it right and the other 3 lights are flashing, its not your flasher. If none of the lights are flashing then yea, it might be. If you look at the schematic above ... Read more >>
March 18, 2022 * 9 posts * 142 views
NEURON said: I use a piece of 4x4 wood and a sledge on the backside of the wheel/tire. Turn smack repeat. I have seen this from corrosion and overtorquing. Read more >>
March 17, 2022 * 1 post * 15 views
Bdenmark73 said: 1998 mustant gt ... A question or 2 concerning constant control relay modules... is it possible for one to be intermittently bad to cause a fuse to blow if it is grounding out? ... Read more >>
March 17, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts New headers/midpipe and intake. March 17, 2022 * 12 posts * 69 views 94-95 5.0 - Specific Bassani mid length gaskets March 16, 2022 ... Read more >>
Continue reading...
