Highlighted posts from Friday, Nov. 19, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
November 18, 2021 * 12 posts * 87 views
Chip66 said: Hmm... They make 12V electric fence chargers for farm animals that run for weeks on a battery. String the hot wires hanging just below the car. Add the 1970's dragging ground straps ... Read more >>
November 19, 2021 * 43 posts * 339 views
ttocs said: actually I could hardly see the links to them on the dark mode and didn't notice them till you said this. Looks like an easy way to break it but I will look into it if the tool ... Read more >>
November 18, 2021 * 16 posts * 167 views
Adfalenski said: It sounds like you have a loose connector somewhere. Loose connections can cause high current and/or intermittent operation. Is there a common connector or connectors to all these ... Read more >>
November 18, 2021 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts ABS Unit Hole Stripped November 15, 2021 * 7 posts * 65 views 96-04 - 4V Specific '94 GT Stock Exhaust Diameter? November 14, 2021 ... Read more >>
November 19, 2021 * 7 posts * 131 views
Flade said: It depends on your manifold. Some Explorer manifolds have internal EGR and some don't. You need to look at your upper manifold to determine which type you have. I would also look ... Read more >>
November 18, 2021 * 26 posts * 788 views
Daryl said: When it's all said and done, SOOO many of the good ones were already taken. So, I defaulted to a very vanilla/ generic: SN95SNK And only took State of California 6.5 months, as ... Read more >>
Continue reading...
