SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 12, 2022 * 11 posts * 105 views
Stangswagalicious said: So under a load, would that mean i cant do it sitting still? I can rev the motor in the garage in all but then in my head its not under an actual load. The MAF and injectors are ... Read more >>
June 12, 2022 * 6 posts * 80 views
dwcopple said: I removed the entire rear shelf setup today and installed 6x8 Pioneer 4 ways I had here in the now empty shelf and tapped their leads to the prior tweeter leads (full-range). Sounds ... Read more >>
June 13, 2022 * 1 post * 13 views
SN95Newsletter said: Click here to view on the web Highlighted posts Sorry to repeat, but does anyone know what this plug is for? June 11, 2022 * 17 posts * 60 views General Tech Spark knocking galore... ... Read more >>
June 12, 2022 * 30 posts * 487 views
ttocs said: This is the kit you want to use. [link] Now there is an easy way to wire in a 4 channel amp and run no more wire than what is needed to go from the amp to the rear speakers. What ... Read more >>
Continue reading...
