Highlighted posts from Monday, Mar. 21, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
March 20, 2022 * 53 posts * 430 views
Snorky said: Both of you have some valid points. I myself have done the blower and cams. Then forged the bottom end. Then added ported PI heads. I will say I wish i spent the extra thousandish ... Read more >>
March 21, 2022 * 12 posts * 83 views
Makoto said: Here's how i confirmed the distance discrepancy. the metal caliper and the fingers are the gap from the other side. [image] the distance of the other side minus this side equals ... Read more >>
March 21, 2022 * 4 posts * 49 views
Gregomatic said: When It popped (loud metallic clank like two hammers together) I could feel it in my seat and stick shift, so I wasn't sure. I figured it was the diff, but the gears didn't look ... Read more >>
March 20, 2022 * 2 posts * 39 views
lwarrior1016 said: Yes they will go on. Make sure you have the correct head gaskets, the Windsor and Romeo heads have different oil ports. The windsor heads also have more bolts in the cam covers ... Read more >>
March 21, 2022 * 50 posts * 310 views
Carl The Cobra said: Well good update had quite a bit of time to work on the car got the front passenger turn signal good and working multifunction switch got delayed so I am hoping to put that in ... Read more >>
March 20, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Engine swap planning - analysis paralysis March 19, 2022 * 33 posts * 286 views Engine Swap Tune up March 19, 2022 * 8 posts * 76 ... Read more >>
Continue reading...
STITCHSCREWW
