Highlighted posts from Monday, May. 16, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
May 16, 2022 * 16 posts * 105 views
Ben Jones said: Okay so driving it today, I remembered when I rode with the dude when I bought it and i remembered him babying it all the way to 3k before he'd shift it and I asked him why he ... Read more >>
May 15, 2022 * 18 posts * 239 views
white95 said: This will give you an idea how a torque arm/panhard bar & coil over equipped, slammed SN95 with delrin and heim joint suspension rides: [link] NVH IS LIFE Read more >>
May 15, 2022 * 6 posts * 31 views
Booboo said: 1997 GT 4.6l. 120k miles. Idles and runs pretty well. It is sluggish accelerating. I hooked up Forscan Lite to see if I could find anything that doesn't look right. I found the ... Read more >>
May 15, 2022 * 6 posts * 44 views
Shanic18 said: Intake is ok plan on going boosted later. Car has forged rotating assembly, Comp Cam 274, of course the elderbrock intake front battery relocation. Has the new HP tuner pro with ... Read more >>
May 16, 2022 * 9 posts * 96 views
dcm0123 said: The power train control module could cause no crank and intermittent spark issues. The relays used for the cooling fans are undersized, overheat and damage components next to them ... Read more >>
May 15, 2022 * 1 post * 36 views
96Bruh said: Looking for another set, as no one is able to repair passenger side due to serious damage on them, I know abc has some but would like to try and get the original embossed set. ... Read more >>
May 15, 2022 * 1 post * 11 views
SN95Newsletter said: Click here to view on the web Highlighted posts Budget Suspension Upgrade? - (Team Z Tubular K-Member) May 14, 2022 * 14 posts * 134 views Suspension and Brakes High temperature ... Read more >>
Continue reading...
