Highlighted posts from Monday, Oct. 11, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
October 10, 2021 * 7 posts * 50 views
Project Grey94 said: Could you explain the blow-by and valve seals leaking oil not too familiar and is this something that you can do at home thank you for your time and information greatly appreciated Read more >>
October 10, 2021 * 3 posts * 18 views
Jake-96-gt said: I recently replaced the heater core in my 96 Gt project car, which involved disconnecting all the power in the dashboard and removing it. Now that it's all replaced and the wires ... Read more >>
tinnocker said: Replacing the clutch and pressure plate on a 94 gt with 75,000 original miles. No problems with the clutch engagements just wanting thoughts on replacing the clutch slave while ... Read more >>
October 10, 2021 * 5 posts * 37 views
tinnocker said: Here is a little trick to do if you think your problem may be that your driveshaft is out of balance. Get a radiator hose clamp and wrap it around the driveshaft close to where ... Read more >>
October 10, 2021 * 6 posts * 61 views
TrickVert said: Monday - That's a protectant, not a cleaner. I've not used anything other than the car wash soap on mine, but then again it's probably only had a water wash three or four times ... Read more >>
October 10, 2021 * 2 posts * 12 views
Monday said: Will a 2019 FORD MUSTANG 5.0 GT AUTOMATIC 10R80 10SP TRANSMISSION bolt up to my 1996 GT 4.6L SOHC?? I gotta lead on one... Read more >>
October 10, 2021 * 1 post * 14 views
Rich said: So as the title states, I have been unable to get the top in my '04 convertible to retract or extend from the completely up or completely down position. I've gone through over ... Read more >>
October 10, 2021 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts To go double din or not? October 09, 2021 * 19 posts * 207 views Electrical & Stereo 1995 Mustang Gt Part out October 10, 2021 * ... Read more >>
October 10, 2021 * 20 posts * 242 views
Michael Plummer said: I'm happy to hear everything worked out for you. Good luck Michael Plummer Read more >>
Continue reading...
