Highlighted posts from Saturday, Feb. 05, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 04, 2022 * 18 posts * 249 views
07GtS197 said: If it ain't broke don't fix it. My vote is to leave them be. They're not really a preventative maintenance item, replace them when they cause issues. Read more >>
February 04, 2022 * 4 posts * 32 views
Jason.Silus said: Yes I had pulled the gauge out, but no matter how the copper traces were set, the fuel guage would never work, and it was the only one that didn't work. Every other gauge works ... Read more >>
February 04, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Pothole leads to misfire... February 03, 2022 * 17 posts * 211 views 96-04 - 2V Specific TR3650 1-2 shift problem, what fluid? February ... Read more >>
February 04, 2022 * 9 posts * 84 views
ttocs said: its easy as long as you find both locating and correctly wiring the 8 input wires, the 10 output wires, and then power/ground/trigger no problem. I don't mean its physically difficult, ... Read more >>
February 05, 2022 * 110 posts * 1,014 views
Makoto said: here's what I would do. bypass everything in the fuel pump circuit (and there is a lot) by powering the fuel pump itself with the proper voltage. its return style so it'll just ... Read more >>
February 04, 2022 * 7 posts * 725 views
brandon__203 said: So you just had to weed out the trans harness from the main harness or you had to make some splices. Sorry for all the questions I'm installing terminator x in my 94 gt 5 speed ... Read more >>
Continue reading...
