SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 04, 2021 * 5 posts * 132 views
skidoo said: Doesn't look like it caused a vibration. A little rich but really to read a plug you have to do a run with new clean plugs and kill the engine then look deep down at the porcelain ... Read more >>
June 04, 2021 * 2 posts * 30 views
96laseredcobra said: Ok guys and gals , my v2 supercharged 347 is chewing up main belt . Runs stupid strong but cant seem to get alternator aligned correctly. It's in smog pump location and using an ... Read more >>
June 04, 2021 * 1 post * 15 views
PinkieT said: Had cracked differential carrier. Local specialty shop installed a good used differential with Trac-Loc, new Ford Racing gears and bearing kit, new Summit axles because the diffy ... Read more >>
June 04, 2021 * 1 post * 3 views
SN95Newsletter said: Click here to view on the web Highlighted posts Fuel pump requirements June 03, 2021 * 10 posts * 223 views 94-95 5.0 - Specific Battery drain June 03, 2021 * 8 posts * 149 views ... Read more >>
June 04, 2021 * 25 posts * 331 views
Daryl said: Unfortunately, I think that's the case. That being said though, wouldn't that actually narrow down the culprits to either the battery or the starter? Read more >>
Continue reading...
