SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
May 07, 2021 * 7 posts * 126 views
Frank.JD.Perez said: here is my opinion if you want to go with the mm phb... THE PHB MAKES A HELL OF A DIFFERENCE GET IT my rear set up is some MM HD spherical bushings in the body and urethene on ... Read more >>
May 07, 2021 * 8 posts * 147 views
TrickVert said: The 94/95 Cobra master cylinder's line ports are reversed from those on the GT, so unless one wants to custom-bend new lines or come up with some sort of extension hoses, it will ... Read more >>
May 07, 2021 * 10 posts * 153 views
joe65 said: This! /\ here's a pic of my windsor heads... [image] Read more >>
May 07, 2021 * 15 posts * 292 views
waynenorcross said: I had the Autopower with detachable harness bar and diagonal. I could still take my daughter and friends to the beach. Really stiffened the car up, too. Read more >>
May 08, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts Cam Girdle cracked May 06, 2021 * 9 posts * 117 views 96-04 - 4V Specific 94 GT Cobra brake upgrade about to start... Questions... ... Read more >>
May 07, 2021 * 7 posts * 116 views
Exhausts
RAU03MACH said: do you have the original exhaust where it bolts up to header , cut that to weld in your x off road , with the o2 bung is another way it could be done Read more >>
Continue reading...
