SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
May 13, 2022 * 8 posts * 61 views
ttocs said: what as been done to the motor? Sometimes after mods it helps to lower the thermostat but it still really should not be needed. As said above the temp gauges in our cars are dumbed ... Read more >>
May 13, 2022 * 9 posts * 49 views
badass98svt said: Mine exploded all over the Cobra behind me on the way to a car show . My buddy was not amused. Definitely was not expected. Read more >>
May 13, 2022 * 11 posts * 104 views
badass98svt said: Me? I pretty much have my suspension all done. Up front: Tubular K Tubular control arms Bumpsteer kit MM solid rack bushings MM solid steering shaft MM coilovers with Bilsteins ... Read more >>
May 13, 2022 * 19 posts * 216 views
lwarrior1016 said: Figures. Just like every damn thing. All the good stuff is back ordered. Read more >>
May 13, 2022 * 8 posts * 64 views
ttocs said: The intake is not the ideal location, you want it bolted to the block itself. While the intake is metal there are a couple of points of connection with gaskets between them that ... Read more >>
May 13, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Ceramic pads vs semi-metallic May 12, 2022 * 9 posts * 61 views Suspension and Brakes 1995 gt intermittent crank no start May 12, ... Read more >>
May 13, 2022 * 11 posts * 180 views
Makoto said: your valve train doesn't give a shit about boost. how about that? safety nanny is traction control, abs, things like that. the tell is the kind of questions you're asking, that ... Read more >>
Continue reading...
